44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rafter to ridge connectionu
Tue, Oct 1, 2013 at 3:27:26 PM | rafter to ridge connectionu
prestijio
Does anyone know how to clean up a rafter to ridge connection? I am using a beam system and where the rafters meet up with the ridge beam I need a flush cut, I have been unable to find my answer, Thanks in Advance
Arturo
Tue, Oct 1, 2013 at 3:37:17 PM | rafter to ridge connectionu
Use a reference plane.
Tue, Oct 1, 2013 at 3:47:53 PM | rafter to ridge connectionu
prestijio
Can you please be a little more specific, I tried reference planes and it still didn't give me a clean cut, the bottom portion of the rafter goes beyond the ridge beam.
Thanks,
Arturo
Tue, Oct 1, 2013 at 3:51:25 PM | rafter to ridge connectionu
You could have found the answer in your HELP:
Structural Member with Plane
Use the Cut Geometry tool to cut a structural member with a plane. For example, use Cut Geometry to cut a column to a certain height, or to stop a beam at a wall.
To cut a beam at a wall
  1. Create a reference plane in the plane of the wall where you want the cut to occur.
  2. Click Modify tabGeometry panelCut drop-down (Cut Geometry).
  3. Select the beam to be cut.
  4. Select the reference plane.
    If you move the wall or the beam, the cut will persist at the wall unless the beam is no longer joined with the wall.
Wed, Oct 2, 2013 at 2:28:33 PM | rafter to ridge connectionu
CDWdavid
5 Stars: 5 Votes
Hi Prestijio,
If you want to cut the bottom of rafters as well, you need two planes, one vertical and one horizontal.
The trick to use reference plane is that you have to do it multiple times.
If you have 20 rafters, you have to click the rafters 20 times in elevation view.
Edited on: Wed, Oct 2, 2013 at 3:16:30 PM
Wed, Oct 2, 2013 at 4:37:25 PM | rafter to ridge connectionu
prestijio
Thank you, struggled a little with this one but, figured it out eventually, just a matter of asking the right questions.
Good day!
Hip Board
Sat, Oct 1, 2005 at 9:41:52 AM
FULLY parametric rafter?
Mon, Jul 23, 2007 at 6:46:47 PM
Trouble with Valley Beam
Tue, Nov 30, 2010 at 11:29:06 AM
Drawing a hip rafter in massing
Tue, Aug 12, 2014 at 4:33:04 PM
truss vs rafter roofs
Fri, Mar 21, 2014 at 11:29:24 AM
Page generation time: 0.4624
