62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> make an irregular window
3 Posts No Rating |
how can i make a window that is not a rectangle?
i made a family but the wall opens a rectangle hole, i need a hole that folow the shape of my window
You need to remove the wall cut from the family and add a wall based void that cuts it instead. PLEASE LISTEN,,,, You will have problems if you don't. Make the void somewhere outside of your element in any shape then set it to cut the wall. After successfully do that, then edit the void to the shape and location you want.
If you initially place the void where you want it, the void will cut all of your components as well as your wall.
3 Posts No Rating |
soory i really new usining revit, could you tell me step by step?
Download the families guide and read it....
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
3 Posts No Rating |
thank you!
how to make an irregular slope surface |
Fri, Apr 1, 2011 at 10:12:27 PM
Irregular Ceiling |
Mon, Aug 4, 2008 at 1:45:52 AM
Curving a Truss around an irregular mass |
Sun, Mar 1, 2009 at 8:19:44 AM
Triangular bay windows |
Wed, Feb 16, 2005 at 8:01:13 AM
irregular patterned stucco wall |
Tue, Jan 27, 2009 at 9:03:41 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
