Forums >> Workflow & Implementation >> Hardware >> Problem with Revit 2013 Not Responding
9 Posts No Rating |
I have a problem with revit 2013 - everything was fine for one month- My revit2011 runs ? no problem. So I open the project in 2013 and start working on it I move few things, edit text, and revit gets stuck, on the top it says::: (Not Responding) you click again, screen goes white- if you try to close the program - It says the program may respond agan if you wait.. I can End Process - I can minimize, windows is running I tried different drawings, it does the same thing. I tried everything I possibly could: update my graphic drivers, windows updates, re-install revit, I did clean the temp files, registry cleaning--- no luck...
my comp spec: win 7 professional 64 bit, 8gb ram running on xeon e5630 @2.53ghz (4 cpus)~2.5ghz
comp model : Dell T3500
How many windows do you have active when this happens? Revit has to update every active window when you change a model element. Depending on view settings, this can be a problem.
9 Posts No Rating |
just one, Now I clicked on Insert to load up new family? and it froze on me, So i guess no matter what I do It will freeze just by clicking on random things. Project is do next week, Yesterday I put about 7 hours trying to fix that problem, no luck. damnit.
Edited on: Thu, Sep 26, 2013 at 10:48:26 AM
You don't say if you have hardware acceration turned on or off. Turn it off and see what happens.
Also - you don't say if you have both updates installed for 2013. If not, then install those.
9 Posts No Rating |
Sorry, with Acc off or On, no luck (no graphics-related problems detected) I even updated my revit to release 3.
Did you restart revit after turning hardware acceleration off? It has to be restarted.
9 Posts No Rating |
yes. I wonder If I can turn on some kind of LOG so i can see what's going on.
Edited on: Thu, Sep 26, 2013 at 10:58:22 AM
9 Posts No Rating |
what i see now is: even when I click on the menu bars, without loading up the project - it freezes. Maybe has to do something with windows it self? But my autocad is working and revit 2011.... strange.... very strange.
9 Posts No Rating |
I think I Found the problem guys,
Usually the best solution is to see which program/addon you installed last. few days ago I installed ProjectWise - I thought about this The day before, well I uninstalled projectwise from my computer, everything is working fine.
Oh well, problem solved. thanks!
Edited on: Thu, Sep 26, 2013 at 12:24:25 PM
I realize the issue wasn't enough ram, but you might want to consider boosting up to 12Gb RAM anyway. What video card are you running?
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
9 Posts No Rating |
NVidia Quatro FX 1800 -After uninstalling projectwise, everything went back to normal.
I'm going to boost my memory to 12 GB. I monitor the memory usage and sometimes I reach 8gb.
Revit Architecture 2011 is not responding in Windows 7. |
Tue, May 4, 2010 at 12:09:32 AM
revit freezing and not responding when cad file linked |
Fri, Feb 6, 2015 at 11:24:56 AM
inserted dwg view problem in 2013 |
Tue, Oct 29, 2013 at 5:24:27 AM
The 'F' Key |
Wed, May 28, 2008 at 8:32:47 PM
slope annotation problem in revit 2013 |
Fri, Apr 12, 2013 at 1:37:44 PM
Members: | 2115604 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
