Forums >> Community >> The Studio >> Quality 3D Renderings?
9 Posts No Rating |
I am looking for a site to download Military Vehicles and Military people, and a BMW Z3.
But I want to be sure if I have to purchse these downloads, that the colors/materials will render properly in Revit. (alot of those free-bee download cars just render grey)
20 Posts No Rating |
jws,
Most of the time, the reason why things render grey in Revit, is due to the fact there is a misplaced map, or the path (originally defined) is wrong. Once an object is imported into Revit, you can go into either its properties or to Settings > Object Styles > Imported Objects and define what materials need to be there.
Keep in mind if you bring in a nicely modeled car, etc. that has really nice glossy paint on it, you will not get the same output from Revit that you would from Max/Viz or others. The render engine doesn't have that capability at the moment. Can you get a nice render, sure! But you might have to play or tweek with the materials first.
Hope this helps,
Kyle
Rendering Quality |
Tue, Feb 26, 2013 at 10:20:32 AM
11
Renderings |
Fri, Oct 23, 2015 at 9:21:13 AM
higher-quality renderings |
Tue, Nov 14, 2006 at 9:21:51 AM
import revit renderings into autocad |
Mon, Jan 17, 2011 at 2:18:18 PM
Render Quality |
Thu, Apr 28, 2005 at 3:27:48 PM
Members: | 2104018 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
