99 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Lines from different wall types showing up in elevation
Tue, Sep 24, 2013 at 3:35:09 PM | Lines from different wall types showing up in elevation
galapito
Using Revit 2013 - Using two wall types for exterior walls - main wall type is a CMU exterior-air gap-studs - gyp bd, wall type two is an 8" CMU. This occurs 8'-0" A.F.F. at all entry alcoves.  In elevation, there are lines at the juncture of these two wall types. I've searched the forums and have tried join geometry with no luck. I've attached the elevation.  Any help would be appreciated.
Tue, Sep 24, 2013 at 3:43:22 PM | Lines from different wall types showing up in elevation
galapito
Never mind, I figured it out.  Onward and upward!
Tue, Sep 24, 2013 at 10:07:47 PM | Lines from different wall types showing up in elevation
tectacoma
tectacoma Avatar
Hi galapito,
it's always recommended to leave an explanation on how you figured out the problem.
Remember, somebody else might have the same problem and is looking for a solution. Winking
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:25 AM
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:07 PM
Undesired Lines in Elevation
Wed, Sep 12, 2007 at 11:38:25 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:33 AM
Grid lines not showing in elevation
Mon, Mar 15, 2010 at 1:30:22 PM
Page generation time: 1.4795
