68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> 3DStudio max 13 and linked Revit files
Tue, Sep 24, 2013 at 10:58:20 AM | 3DStudio max 13 and linked Revit files
Jinxt3r
Why is it that every time I need to refresh my linked Revit file in 3dstudio it fails to connect to Revit and reports the the file may be missing or corrupt?  I must close out 3Dstudio, restart it, and only then will it allow me to refresh/reload the Revit file.  If I make a change to my Revit project and have to refresh it in 3Dstudio again, I must repeat the shut down process.  It is annoying to say the least and very time consuming.
Thu, Oct 10, 2013 at 9:42:57 AM | 3DStudio max 13 and linked Revit files
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
I found that its helpful to close out of the Revit {3D} view (or subsequent camera view, whichever you import) and THEN hit save in Revit.  Only then should you reload the revit model in 3dsMax.  What's weird is that doesn't work everytime, but I know what you're saying.  Its frustrating.  Sometimes I just close completely out of revit before I reload in Max.  That has worked 100% of the time.  I presume that max has a glitch in it that once the revit model has had X number of changes, lets say 100, it won't reload without completely having to close out.  It gets "hung up" on something.
Also, did you notice that not all the material settings transfer properly?  Try creating a tiny perforated metal (circular holes + cutouts) and then import it into 3dsMax.  The holes are 10 times larger than what you specified in Revit.
Best of luck!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Thu, Oct 10, 2013 at 9:52:11 AM | 3DStudio max 13 and linked Revit files
Jinxt3r
Thanks for the advice.  I will take it into consideration.  As it stands, Autodesk tech support has looked into the issue and are at this time unable to provide a successful resolution.  They have informed me that the issue has been passed to the software design/engineering team.I have indeed noticed the material changes and I beleive that to be a 3Dstudio setting under "system units".  However, I only apply materials to items in Revit as a reference.  I normally customize or replace those materials once brought into 3dStudio.
Thu, Oct 10, 2013 at 10:05:03 AM | 3DStudio max 13 and linked Revit files
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
I customize some materials in 3dsMax too.  Have you been able to find a way to not let Revit override 3ds materials once you've changed them?  I know there's a checkbox for "lights, materials, cameras" but I have found that doesn't do anything to my model whether or not those are checked or not.  Makes me not want to reload my revit model passed a certain point.
but hey, at least we don't have to export to FBX and import anymore.  I like the linking feature, huge improvement in terms of workflow.  this stuff we're dealing with is minor.  glass is half full.  Winking
RB Cameron
Thu, Oct 10, 2013 at 10:22:48 AM | 3DStudio max 13 and linked Revit files
Jinxt3r
Yes, when you link a Revit file in 2013, there are two check boxes located at the bottom.  One is to retain 3dStudio material overrides of linked Revit materials, and the other is to retain 3dStudio material assigments to objects upon reload of linked files.  I prefer to keep both of these boxes checked since I am the only one in the company using 3dstudio.
Importing from 3DStudio Max
Mon, Apr 18, 2011 at 2:04:03 PM
3DStudio objects
Mon, May 8, 2006 at 10:06:13 AM
Revit that contains linked revit files - linked to 3ds max design fails
Mon, Feb 24, 2014 at 4:59:33 PM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Page generation time: 3.8858
