59 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Custom rafters/roofing Revit 2012
160 Posts No Rating |
The roof in the attached image needs to be customised at the edges. I have highlighted a rafter poking out of the roof in the plane that the rafters will run(there will be no fascia) then at the edges of the roof at 90deg (the barge or verge) I will have end trimmers or sprockets (call them what you will depending where you come from). I would like to shape the ends of these rafters & sprockets to create the same profile as the fascia ends of the rafters.
To a great extent I do not need to model them as I can detail them, but it would good to show the shape in 3d so that there is some continuity for the clients as they are very concious of the style of the house.
I suppose could create a roof by profile but then it would be hard to customise the ends, or would it??
Any help will be greatly appreciated.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Totally don't understand what you are trying to do. No idea why the rafter is poking through the fascia and how it comes into play.
We need a 'what you get vs what you want' image or sketch.
Edited on: Tue, Oct 8, 2013 at 2:52:42 PM
Yes dgcad, not a very good description of my request.
I have been able to create the description of what I am after in the elevations but not in the model. I would like to model the roof element to suit the roof in the attached image.
Cheers Dermot
www.dmbd.net |
try creating a special profile as a fascia, with the angled cutback as u require.
possibly do the roof just as the roof decking so it doesnt protrude thru the special profile.
then fill in the raters and purlins, sarking and insulation etc on the section in 2d.
similarly the soffit lining would be separate. as well.
just my thoughts
cheers
geoff
So do the roof as just colorbond at 16 mm then have a fascia profile as deep as the roof system is thick with the 600mm rake.
I wil give it a try, thanks a lot.
Cheers Dermot
www.dmbd.net |
Thanks Geoff
I gave it a try and it looked good!! but the fascias would not miter at the corners. The corners on my roof are not 90deg which I think maybe wnat Revit cannot cope with.
Cheers Dermot
www.dmbd.net |
Here is an image of the problem.
Cheers Dermot
www.dmbd.net |
Exposed Rafters- Revit 2012 |
Thu, Aug 9, 2012 at 9:18:10 AM
drawing angled roof rafters |
Tue, Aug 18, 2009 at 11:53:17 AM
Roofing Material Look alike |
Wed, Nov 21, 2012 at 5:35:57 PM
Custom Rafter Tails & Roof in Revit 2012 |
Thu, Aug 7, 2014 at 2:53:02 PM
Revit Roofing |
Tue, Mar 23, 2010 at 2:30:31 PM
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
