161 Users Online (160 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> VIEW UNITS OVERRIDE
Sat, Sep 21, 2013 at 4:26:33 PM | VIEW UNITS OVERRIDE
mongopac
I know it can be done, but I can't figure out how and WikiHelp is, as usual, useless.
I want to override the project units in a site plan view.  How is this done?
Mon, Sep 23, 2013 at 8:05:30 AM | VIEW UNITS OVERRIDE
Your question is not clear.  Are you asking about view scale?  Are you asking about dimensions?  Are you asking about elevation tags?  What?
Mon, Sep 23, 2013 at 8:10:30 AM | VIEW UNITS OVERRIDE
Pt88
manage>project units (settings tab)
Mon, Sep 23, 2013 at 8:16:41 AM | VIEW UNITS OVERRIDE
Project units are for the PROJECT!
You can set up all annotations so they DON'T use project units if you want.  So again, what are you wanting?
Mon, Sep 23, 2013 at 11:01:18 AM | VIEW UNITS OVERRIDE
mongopac
It seemed to me that I have, in the past, disabled project units in specific views by unchecking the project units box in some dialog that I can't recall and then customized the units in the particular view.  In this instance I wanted the site plan at 1/40" scale to simply report in rounded feet rather than the the usual 1/8" tolerance I generally use in floor plans.
Maybe I'm just nuts. Is that not possible?
Mon, Sep 23, 2013 at 12:39:35 PM | VIEW UNITS OVERRIDE
If you are talking about temprary dimensions, then that uses project units.  But you can set a dimension type that rounds to whatever you need.
We only model at 1/256" and for 99% of our dimensions, that works because we model accurately and we don't see any units below 1/8".   However, there are instances where we don't want any fractions or perhaps there is an element that has very small units.  For those instances, we have a rounded dimension that is named accordingly.
cannot override graphics by category
Thu, Jan 19, 2017 at 2:46:12 PM
Conversion from English Units to Metric Units
Tue, Feb 17, 2009 at 4:32:53 AM
Multiple units on sloping site
Tue, Feb 21, 2006 at 3:29:30 PM
Fixture units
Wed, Apr 23, 2014 at 8:16:47 AM
is it possible to disable phasing Graphic Override on a view
Thu, Jun 8, 2017 at 3:34:47 PM
Page generation time: 1.0671
