Forums >> Revit Building >> Technical Support >> Phase control in Revit
17 Posts No Rating |
Hi
Is there any phase control fuction (except phase filter) in Revit so I can assign different colors for different phases (similar as the worksets control fuction ).
Or is there any other way (except phase filter fuction) to check if all the elements are in the correct phases.
Thank you
Phased items can also be placed in worksets.
Thank you for your reply.
How to do that to show colors ?
You wrote that you wanted to "...is there any other way (except phase filter fuction) to check if all the elements are in the correct phases...."
Obviously, you can use phase filters - just change the phase material. Or - with worksets, you can isolate the workset.
Get it :-)
Thank you
Hi
I have one more question.
I have already assigned materials / colors for phases, however these colors are not shown.
How can I show the colors in my model?
Thank you.
Future Phase |
Tue, Sep 9, 2008 at 2:18:30 PM
New Construction phase cuts Existing Phase |
Tue, Aug 9, 2011 at 12:21:58 PM
Display Phase I & Phase II Room Names Together |
Fri, Jan 11, 2013 at 2:53:40 PM
Current phase? |
Fri, Nov 7, 2008 at 9:09:31 AM
Revit Link Phase |
Thu, Apr 17, 2014 at 12:04:43 PM
Members: | 2114919 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
