97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall family with parametric array
24 Posts No Rating |
Hello guys, I'm tryin´to build a parametric louver for a curtain wall panel, but it´s not working in the project environment. In the family environment it flexes well. The array system is built as a generic family, and each individual louver is another generic family extrusion.
Can someone take a look to the family?.
Thanks in advance!
![dingohot Avatar](user_avatar/155924.jpg)
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
change the 'height'parameter in louversystem.rfa to 'instance', not 'type' i suppose it should work.
and you can't name on height in panel template. just use constraint.
Edited on: Mon, Sep 16, 2013 at 4:05:59 AM
want more?
You can get more tips at Enjoy Revit |
Thank you very much!, your panel works great, but I can't get mine to work. Is too stiff, I constrained my array system to the top and base but it breaks. I will inspect your panel and star from scratch. Thanks again
Edit: Dingohot, I made it work, reloaded into a fresh new curtain wall family and constrained manually as you said.
Great tips. Thank you for taking the time, I really appreciate it. keep it up!
Edited on: Mon, Sep 16, 2013 at 12:55:41 PM
My pleasure.
Enjoy. :-)
want more?
and here is simpler way to make what you want.
http://youtu.be/knTUBOuL7oc
Enjoy. :-)
Edited on: Mon, Sep 16, 2013 at 8:07:57 PM
want more?
great video!, thanks
Array Parametric in Family |
Tue, Nov 25, 2008 at 1:54:57 PM
Editable nested family inside parametric array host family |
Wed, May 19, 2021 at 8:05:22 AM
Parametric Arrays |
Fri, Feb 5, 2010 at 3:19:22 AM
Parametric Array Constraints |
Tue, Jul 2, 2019 at 7:00:45 AM
Array on a Parametric Face |
Tue, Mar 7, 2017 at 5:09:10 PM
Members: | 2017373 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
