73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Pendant Lights on a sloped ceiling
Thu, Sep 12, 2013 at 7:06:51 AM | Pendant Lights on a sloped ceiling
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I am using Revit Arch 2013 and need to get pendant lights suspended from a sloped (5 degrees) generic compound ceiling vertically (ie; not at an angle) but at the same height to the underside.
I have already read various discussions on this board but have not yet found the solution to fully acheiving the above. I either get the pendants hanging vertically at different height or I cannot get them to hang vertically to begin with becuase the family type is incorrect.
I would very much appreciate someone spelling out exactly which family type I need to achieve this, the pendant light model already exists ready to copy and paste into the family, I just need to ensure that when I complete this 'new' family I can check 'always keep vetical' and adjust the 'drop' for each instance.
Many thanks,
CM.
Thu, Sep 12, 2013 at 8:00:43 AM | Pendant Lights on a sloped ceiling
3.5 Stars: 395 Votes
Here is a pendant that does what you want.  Use it - change it - or follow it as an example.
http://www.revitcity.com/downloads.php?action=view&object_id=2911
BTW - Reread your first sentence because it doesn't make sense as written.  Communication in all forms is important in our business.
Edited on: Thu, Sep 12, 2013 at 8:02:18 AM
Thu, Sep 12, 2013 at 8:47:17 AM | Pendant Lights on a sloped ceiling
Chunkymonkey
5 Stars: 3 Votes
Thank you for this, I see what you mean about the first sentence.
This is exactly what I need, I may be being silly but once a series of these pendants are in the model how can I get them to sit at the same level to the underside? I click on the properties but there is no option for the length of drop available, none that i can see at least.
Many thanks,
CM.
Thu, Sep 12, 2013 at 9:19:42 AM | Pendant Lights on a sloped ceiling
Re-look at my image - the answer is there.
Pendant light placement
Wed, Sep 19, 2007 at 4:03:08 PM
Recessed Lights in Sloped Ceiling
Thu, Dec 13, 2007 at 10:23:28 AM
Ceiling lights not working
Thu, Feb 26, 2009 at 4:10:57 PM
Pendant light mounted to sloped ceiling
Tue, Oct 30, 2018 at 8:37:08 PM
13
Illuminating Pendant Lights
Tue, Nov 16, 2010 at 2:38:07 PM
Page generation time: 0.4116
