38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> surface pattern visibility
Wed, Sep 11, 2013 at 5:40:14 PM | surface pattern visibility
ledgewood33
I have a concrete foundation wall and I able to see 3 out of the 4 surface patterns. of course some my section are in the view that the fourth surface which doesnt show the pattern.
Thu, Sep 12, 2013 at 7:10:42 AM | surface pattern visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"of course some my section are in the view that the fourth surface which doesnt show the pattern."
This makes no sense.  Are all of your foundation walls at the same height so your view range is cutting through them?  Are they all the same type of wall?  Are they all on the same phase?
Thu, Sep 12, 2013 at 9:10:53 AM | surface pattern visibility
ledgewood33
Yes, all of your foundation walls at the same height.the cut pattern is not in question. when I actually cut through the foundation wall the cut pattern shows up. its the surface pattern on one side of the wall that is not showing. all the VG is set correctly. the reason this causes an issue is some of the foundation walls are slightly above grade.
Thu, Sep 12, 2013 at 10:23:19 AM | surface pattern visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Post an image of your problem.  Do you have a surface pattern applied in the material?
Thu, Sep 12, 2013 at 2:02:13 PM | surface pattern visibility
ledgewood33
the surface material is applied to the material. I am attaching two pdf's
Fri, Sep 13, 2013 at 9:11:03 AM | surface pattern visibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have any graphics been overridden in that view?  Is there anything infront of them that would be hiding the pattern?
Edited on: Fri, Sep 13, 2013 at 9:11:27 AM
Fri, Sep 13, 2013 at 9:46:30 AM | surface pattern visibility
Is the wall placed correctly - outside finish out?  (And the wall built that way)?
surface pattern visibility issues
Thu, Jan 5, 2006 at 3:13:48 PM
Mon, Dec 8, 2008 at 4:14:15 PM
Surface pattern
Mon, Sep 10, 2007 at 11:18:02 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:34 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:01 PM
Page generation time: 0.5550
