68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problems opening pre-loaded steel families in Revit Structure 2012
Tue, Sep 10, 2013 at 9:39:07 PM | Problems opening pre-loaded steel families in Revit Structure 2012
Tye441
Has anyone encountered this problem before where I have placed a few steel members in a new project, however whatever members I use I am unable to edit the original family. See image attached. It just give sme the option to "load family" which when you select doesn't work. I am trying to open the family to delete the cut-back that is set by default.
Tue, Sep 10, 2013 at 10:26:36 PM | Problems opening pre-loaded steel families in Revit Structure 2012
ronmalit
5 Stars: 3 Votes
if you can browse your family and right click and edit it then it should be a revit ribbon issue
i think try to search relative hot fix/patch for RA2012 for this ribbon issue. try to search on your Subricption.
** dont be mad, i dont have much... i am homeless
No families loaded in revit 2012
Fri, Jul 13, 2012 at 7:04:38 AM
Steel Structure
Fri, Mar 11, 2005 at 1:39:35 PM
Using families from Steel Select.com
Thu, Jun 19, 2008 at 7:15:33 AM
Revit 2012 Truss System (framing members not showing)
Wed, May 9, 2012 at 9:25:33 AM
revit steel questions
Mon, Apr 6, 2015 at 9:27:20 AM
Page generation time: 2.2671
