Forums >> General Discussion >> Revit Project Management >> Hardie Board Panels
2 Posts No Rating |
I am fairly new to Revit and wish to make an exterior wall material out of Hardie Panel/ Fiber Cement Board panels, but can't find a way to do that. At this point, it doesn't have to be structural- I just want to use the paint tool to apply the look of the material on the outside of my building (or whatever is easiest).
Fiber cement board panels are not a default material in my Revit materials library. How can I create a fiber cement board material or where can I go to get one?
Hardie boards can be ship lap or flat panel. For shiplap, just use a wood shiplap material. For flat panel, the board just has a thickness and a color..... you can handle that I'm sure.
2 Posts No Rating |
Sounds simple enough, but again there's still a lot I've yet to learn- are you saying just use a generic shiplap/panel material, or to custom make the boards/panels as a component/family/material? I'm not quite sure how I would do what you suggest.
Certain 3D elements you just don't model in Revit because it will overwhelm the model. Basically, you don't model materials with like 1/2" variation in texture. Instead, you use materials with a 'bump' factor that give the illusion of depth. Elements that we only use materials on include shiplap siding, shingles, bricks, blocks, standing seam roof and materials that are 'pierced' like chain-link fence.
Cement Fiber Board Panels |
Tue, Jan 9, 2018 at 2:20:09 PM
curtain walls make like partition walls |
Sun, Oct 26, 2008 at 2:03:29 AM
Fascia Board Too Long |
Tue, Nov 20, 2012 at 10:19:32 AM
Turning certain curtain panels into spandrel panels |
Tue, Dec 3, 2013 at 1:59:48 PM
frieze board |
Sun, Jan 8, 2006 at 11:21:02 PM
Members: | 2099130 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
