75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Roof hip with different height fascia
Mon, Sep 9, 2013 at 12:39:01 PM | Roof hip with different height fascia
chjcnmc
Hi, I have a problem with two seperate roofs on each end I need a hip. the problem is the hip side needs to have a different height gutter/fascia. pictures are attached for help, thanks!
Mon, Sep 9, 2013 at 12:41:58 PM | Roof hip with different height fascia
killanena
tricky one also stuck on this if any1 can help please
Mon, Sep 9, 2013 at 12:47:30 PM | Roof hip with different height fascia
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is a dutch hip. Sketch your roof and select the roof edge line in your sketch that you want to be your hip and under properties change the Offset from Roof Base to the elevation you want your hip to start at.
Mon, Sep 9, 2013 at 12:53:11 PM | Roof hip with different height fascia
killanena
thanks will try this
Mon, Sep 9, 2013 at 1:00:10 PM | Roof hip with different height fascia
chjcnmc
It worked all I need to do now is get it as close to the original house I'm modelling. many thanks teafoe5!!
Mon, Sep 9, 2013 at 1:01:25 PM | Roof hip with different height fascia
chjcnmc
let me know if it works for you Killanena...
Mon, Sep 9, 2013 at 2:25:28 PM | Roof hip with different height fascia
killanena
yes works perfect , thanks for the help, was gettin frustrated with it
Can't get fascia heights to match
Thu, May 19, 2011 at 4:57:16 PM
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 10:07:01 AM
Fascia Sweep not mitering
Tue, Aug 25, 2009 at 4:01:20 PM
12
RAC09 - Roof Fascia Corner Miter on Square Cut
Wed, May 27, 2009 at 6:57:01 PM
Hip Roof Issue
Mon, Mar 24, 2008 at 1:30:09 PM
Page generation time: 1.9252
