68 Users Online (67 Members):
Forums >> Revit Structure >> Technical Support >> Rebar message issue
4 Posts No Rating |
Why does every time i try to rebar an element, for example columns, (or any other element ) pops a message that says " Hooks will not be included in Rebar Shape definitions. This option can be changed under Reinforcement Settings , and shoud be set before adding any Rebar elements to the project" This message appears no matter of the settings I am doing ( about what the message says), about hooks or anything else..
How do I get rid of it? Or what setting I really have to do to use the rebar function correcly?
I mention that I am a student, therefore I am using Revit 2014 with student licence.
(I attached a print screen picture about the message )
![5 Stars: 3 Votes](/images/stars_5.gif) |
ignore..
you still can add rebar and choose shape, then you can set start and end hooks after placing rebar
** dont be mad, i dont have much... i am homeless |
Place varies lenght rebar on revit. |
Mon, Feb 18, 2013 at 8:04:57 PM
Rebar - Multiple Layout Issue |
Fri, Mar 1, 2013 at 3:33:30 PM
How to apply the rebar in a ramp. |
Mon, Jul 5, 2010 at 4:53:04 AM
Need help to modify rebar bar size!!!!! |
Thu, Apr 6, 2017 at 3:03:05 AM
Revit 2016 - Rebar note |
Wed, Jul 29, 2015 at 9:21:12 AM
Members: | 2017201 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
