40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Rotate model hatch on curved roof
Wed, Sep 4, 2013 at 9:57:57 AM | Rotate model hatch on curved roof
romanosyr
I have an eyebrow roof with two different curves, i need to show beadboard going in 1 direction for the curved soffit. revit will not let this happen for whatever reason the bottom curve is going vertical...(the direction i need) the top curve turns the hatch horizontal, and will not let me rotate.  i have tried painting with a rotated hatch but no success.  any ideas?
Wed, Sep 4, 2013 at 10:08:01 AM | Rotate model hatch on curved roof
Are these two seperate elements?
Is it a created in-place element or a loaded family?   Is it a mass?
Is the hatch a model hatch as it should be?
Wed, Sep 4, 2013 at 10:25:41 AM | Rotate model hatch on curved roof
romanosyr
it is a model in place roof extrusion, the hatch is a model hatch (3" parallel lines).  it has something to do with the curves b/c the hatch rotates without any problem on my flat soffits.
Wed, Sep 4, 2013 at 10:44:58 AM | Rotate model hatch on curved roof
I have always found model-in place materials to be somewhat of a problem.  The material is applied based on the work-plane used.  In the attached view, the extrusion on the left used the horizontal plane you see.  The extrusion on the right used the vertical plane then I rotated it afterwards.
I hope this points you in the right direction.
Surface hatch for roof with curved end
Sun, Jan 24, 2010 at 7:26:35 PM
Curved wall hatch
Wed, Nov 28, 2012 at 4:41:19 PM
Can't get a hatch pattern to appear on a curved roof
Wed, Nov 13, 2013 at 10:43:38 AM
Rotate Model Fill Patterns [ 1 2 ]
Sat, Nov 28, 2009 at 5:21:55 PM
15
Content hatch - rotate with component
Mon, Apr 11, 2011 at 10:22:42 PM
Page generation time: 1.7005
