58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Angular parameters
Tue, Sep 3, 2013 at 6:56:27 AM | Angular parameters
KES1
Hi guys,
Just wondering if i can pick your brains on the following problem i'm struggling to resolve.
I'm building a family (this one is very basic) and trying to use an angular parameter to set the angle at which the outlet occurs.  I've followed examples i have seen on the net during searches (using nested families etc) to find a solution but nothing seems to work.  Any chance one of you can shed some light on where i am going wrong?
when i try and 'flex' the family to see if the outlet moves with a given angle i get an error message saying 'constraints are not satisfied' and tries to move the nested family rather than rotate it.
Any help would be gratefully received.
Adam
Tue, Sep 3, 2013 at 7:44:33 AM | Angular parameters
Is the family you want to rotate set to "always vertical?
Tue, Sep 3, 2013 at 7:56:20 AM | Angular parameters
cketros
I set constrain angle in nested family seem to work ok
Tue, Sep 3, 2013 at 8:03:53 AM | Angular parameters
KES1
Hi WWHub
Yes it is set to 'always vertical', is that a possible cause for it not flexing as it should?
Hi Cketros
Thanks, i'll have a look at how you've done that, i swear i couldnt get it to work within the nested family.
Thanks guys for your promt replies.
Tue, Sep 3, 2013 at 8:14:08 AM | Angular parameters
KES1
Ahh, i needed to make a model group with the reference line within it!!!
Thanks again for your help guys!
Edited on: Tue, Sep 3, 2013 at 8:15:23 AM
Angular parameters Error
Tue, Nov 20, 2007 at 5:50:37 PM
showing angular dimensions in degrees seconds etc
Wed, May 5, 2004 at 7:43:16 AM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
ANGULAR DIMENSION TOLERANCE
Mon, Mar 2, 2015 at 1:00:50 PM
dimensioning angular walls
Wed, Nov 1, 2006 at 2:39:13 AM
Page generation time: 0.9198
