54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Gray Hatch Lines
Sat, Aug 31, 2013 at 7:36:39 PM | Gray Hatch Lines
helli1
I'm using Revit LT and Adobe Pro.
I have gray hatch/fill patterns for most of my patterns.
When I print to PDF, all the lines come out black and appear way to dark.
Is there a way to have them print to PDF "gray" or a very thin black linewieght?!?
Randall
Mon, Sep 2, 2013 at 8:01:02 PM | Gray Hatch Lines
ronmalit
5 Stars: 3 Votes
just want to share
i can print any color that i want using cutePDF writter
its just i doesnt print fill patterns with override transparency.( select my fill pattern, right click, override,adjust transparency)
try to update your pdf pro or look for revit related fix/patch/update
** dont be mad, i dont have much... i am homeless
Material hatch will not print gray, only black
Thu, Jul 14, 2011 at 8:16:53 AM
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:40 AM
How do you darken hatch lines?
Thu, Jul 23, 2009 at 9:41:53 AM
Existing Phase / Ceilings solid gray
Mon, Oct 15, 2012 at 12:40:18 PM
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
Page generation time: 1.5268
