67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Adding Volume Parameter into a family
Fri, Aug 30, 2013 at 9:41:01 AM | Adding Volume Parameter into a family
lbarnett83uk
Hi,
Currently creating a parametric family for a concrete tank structure. The main body of the tank has been created using a revolve. The tank has a sloped body and a number reveals within.
I was wonder if it is possible to add a volume parameter to this tank within the family?
Please Help!!
Fri, Aug 30, 2013 at 9:59:46 AM | Adding Volume Parameter into a family
Have you tried?  Do it.  But you will have to tell it how to calculate it.
Fri, Aug 30, 2013 at 11:37:26 AM | Adding Volume Parameter into a family
lbarnett83uk
The tank is stepped with a hopper pit in the bottom.
Would I have to apply a dim to every face?
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:04 PM
Pulling System Parameter From Nested Family
Wed, Jan 9, 2019 at 8:58:26 AM
Calculating Volume
Tue, Sep 4, 2007 at 2:35:10 AM
Schedule concrete volume (including column, slab & beam) by workset
Thu, Oct 28, 2010 at 8:04:53 AM
adding a parameter in an inclined wall family
Mon, Dec 29, 2008 at 5:29:49 PM
Page generation time: 1.6573
