67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 5:31:20 AM | First floor slab or ground floor ceiling?
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I have built a smallish model which has a ground floor and a first floor above. The first floor 'ground' has been drawn as a concrete slab 300mm thick. Technically this same piece of concrete forms the structural ceiling/soffit of the ground floor also; but Revit (Arch 2013) does not appear to treat it this way. Is there a way that I can assign the underside of the first floor slab as the ground floor 'ceiling'? Or do I have to draw a separate ceiling for the ground floor?
Many thanks,
CM.
Fri, Aug 30, 2013 at 7:41:04 AM | First floor slab or ground floor ceiling?
You can use the "generic" ceiling which has no properties but will host objects.
Splitting the ground floor slab?
Thu, Dec 12, 2013 at 10:44:55 AM
Wall top vs. First floor slab
Thu, Jul 8, 2010 at 10:40:56 AM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:11 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:41 PM
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:02 AM
Page generation time: 0.6114
