Forums >> Revit Building >> Technical Support >> Eave Condition
Thu, Aug 29, 2013 at 5:40:33 PM | Eave Condition
benlink
Revit 2013
I'm drawing a wall section and would like the roof insulation held back at the edge and the plywood and standing seam to extend out over the eave.  See the image attached.  The red "X" is over the section I want deleted.  The other red lines are outlining the rough shape I'm looking for.  I currently have the rafter cut at "2 Cut Square."
Thanks,
.blc
Fri, Aug 30, 2013 at 7:35:46 AM | Eave Condition
For section views, you can use edit cut profile but that doesn't solve the model issue.
You have multiple possibilities here.
  • A void sweep to cut the roof would be one.
  • Two roofs either a thin larger roof of only the top material on a lower roof with your insulation etc would be one,
  • another is a roof with the perimeter at the end of the insulation and an outer roof that is just that extension then join the roofs.
Fri, Aug 30, 2013 at 8:01:13 AM | Eave Condition
benlink
Got'cha.  I've done the layered roof option in the past.  Though, I'm trying to hone my Revit ways toward efficiency and didn't know if there was a better way without juggling two roofs.
Thanks,
.blc
Varying eave heights on roof [ 1 2 ]
Wed, Aug 11, 2010 at 8:21:37 PM
23
Eave Return [ 1 2 ]
Fri, Jan 26, 2007 at 12:09:33 PM
18
butterfly roof, curved in plan and at eave
Sat, Feb 12, 2011 at 8:07:03 AM
If/Then & Yes/No Parameter Condition
Fri, Aug 29, 2014 at 2:18:54 PM
Boxed in Eave Roof
Thu, Jun 14, 2012 at 11:14:54 AM
Page generation time: 0.2333
