48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> surface patter visibility in plan vs elevation
Thu, Aug 29, 2013 at 2:55:22 PM | surface patter visibility in plan vs elevation
ledgewood33
I have column that I created with a tapered stone base that supports a wood column. I would like the surface pattern to show in elevation but not in plan?
Thu, Aug 29, 2013 at 2:59:06 PM | surface patter visibility in plan vs elevation
You can over-ride graphics by element and turn that off or turn off the surface pattern by category if it doesn't affect anything else.
Thu, Aug 29, 2013 at 5:41:57 PM | surface patter visibility in plan vs elevation
ledgewood33
is it possible to turn off the surface pattern only in plan view and leave it on in elevation and 3D?
Fri, Aug 30, 2013 at 3:09:08 AM | surface patter visibility in plan vs elevation
gelo26
4.5 Stars: 2 Votes
yes. use the visbility graphic overrides (VV command) uncheck the visibility pattern for projection surface.
Fri, Aug 30, 2013 at 10:21:21 PM | surface patter visibility in plan vs elevation
ledgewood33
by overriding the visibility graphics as you suggest, wont that turn off the surface pattern in all views of the column?
because my column has a tapered stone base the pattern shows in all views. I dont want to see it in plan view. but I do want to see in in elevation.
Fri, Aug 30, 2013 at 10:54:56 PM | surface patter visibility in plan vs elevation
ledgewood33
I would like this column to work like a door. as a door is created it is actually closed and there are symbolic lines to represent the open door and swing. the closed door is hidden in plan view yet you can see it in elevation.
so maybe instead of the surface pattern alone is there a way to hide the blend that is the column base in plan view and yet shows in elevation?
Mon, Sep 2, 2013 at 2:05:08 PM | surface patter visibility in plan vs elevation
Over-riding graphics IN-VIEW by element<< That is the command and that answers your question.
how to add some pecific pattern of the surface?
Sun, Feb 13, 2011 at 7:54:28 AM
Adding Material to Divided Surface
Thu, Apr 17, 2014 at 10:40:13 AM
topo surface elevation value [ 1 2 ]
Fri, Dec 15, 2017 at 4:15:37 PM
23
surface pattern visibility
Fri, Sep 13, 2013 at 9:46:30 AM
Elevation visibility in linked models
Fri, Feb 25, 2011 at 9:54:39 AM
Page generation time: 4.4506
