34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Topography Schedules and reporting Pad cut/fill.
Sun, Feb 12, 2006 at 5:55:12 PM | Topography Schedules and reporting Pad cut/fill.
psymon
psymon Avatar
3.5 Stars: 6 Votes
I am having trouble creating a topography schedule that shows both the cut and fill created by a graded surface and the cut created by the pads. How do we make a schedule that reports the name of the varoius topographies? There does not seem to be parameter for this? Does anyone have an example of one of these schedules orgive a quick step by step on hopw to create one? Post edited on 2006-02-13 01:52:01
Sun, May 7, 2006 at 6:40:00 PM | RE: Topography Schedules and reporting Pad cut/fill.
itchyitchy
We have done a similar thing (i hope) and in Your scedule, just make sure you have Name, (projected Area and Surface area if you like) (Fill, Cut if you'd like) and Net Cut/Fill, as the Schedule Fields in the Schedule Properties. You can't name a Pad, but you will see them 'appear' in the Topo schedule, so to name them, you click on the piece of topo that 'walls' down/up to the pad, and then Properties and you can name that. It should then appear on the schedule. This is all only applicable if you have made the Topos correctly, (with one on the previous Phase etc.) Hope this helps. Its a nightmare to get used to Chris.
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:16 AM
Topography Cut/Fill Schedule
Thu, Nov 16, 2006 at 11:15:52 AM
Siteworks Cut & Fill
Wed, Jun 1, 2011 at 5:12:57 AM
Cut into Topography
Mon, Feb 19, 2007 at 8:55:24 AM
Building Pad Schedule
Wed, Apr 23, 2008 at 11:12:40 AM
Page generation time: 2.7726
