47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Visibility issues for categories in Revit 2013
Thu, Aug 29, 2013 at 12:54:26 PM | Visibility issues for categories in Revit 2013
Turandot
I was trying to change the color of the walls and doors through changing the color of the whole category: in case of walls only the wall outline was changing the color (it is fine detail level), the other lines remained black. The doors didn't changed the color at all, except those are in curtain walls.
though, changing color be element allows to do so and in general i could pick all doors or walls in the view and to change the visibility by elements, but the template won't read it and i certainly don't want to repeat such procedure for 30 similar views.
...any suggestions, anyone?....
Thu, Aug 29, 2013 at 3:09:49 PM | Visibility issues for categories in Revit 2013
Projection lines and cut lines color line style and lineweight can be set project wide by category through the manage / object styles tab.
Edited on: Thu, Aug 29, 2013 at 3:10:29 PM
Dimension Categories
Mon, Oct 29, 2007 at 10:18:19 AM
Removing categories from Graphic Overrides
Mon, Jul 14, 2008 at 6:58:05 PM
Turning off categories in linked models
Tue, Feb 5, 2008 at 11:28:24 AM
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ]
Wed, Sep 23, 2015 at 2:57:56 AM
19
Collapsing Browser Categories & Sub Categories
Wed, Mar 4, 2009 at 9:29:51 AM
Page generation time: 3.3746
