78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> viewer for Revit 2014?
Wed, Aug 28, 2013 at 4:32:45 PM | viewer for Revit 2014?
andersene
Has anyone figured out how to get a viewer working for Revit 2014?
In the past, we were able to install the free trial version of Revit for people who are allowed to view the model, but not save any changes. When the 30 day trial ran out, folks could continue to view the model as a viewer.
I believe that things changed a little with Revit 2013, which had a seperate "Viewer" mode that you could choose upon installation.
Now, the free trial version of the softare appears to be some sort of online cloud software that blocks your access after 30 days are up. Has anyone installed this yet? Does it work the same? I can't find any information on the Autodesk website about how to get this to work as a viewer, so I'm wondering if they may have changed their policies on this...
Wed, Aug 28, 2013 at 7:57:42 PM | viewer for Revit 2014?
hugh
3.5 Stars: 4 Votes
You should have a StartMenu shortcut that starts Revit @014 in viewer mode by adding "/viewer" to the commandstring just like 2013.
Hugh Adamson
www.hatchkit.com.au
Thu, Aug 29, 2013 at 11:04:03 AM | viewer for Revit 2014?
andersene
Thanks! (for pointing out my blindness)
Wed, Apr 23, 2014 at 3:13:05 PM | viewer for Revit 2014?
SmarterArchitect
There is a informative post on the Autodesk Revit Viewer
I did some research on this topic as well to answer others questions.
The video which covers how to install it, features, etc is here
Let me know if it helps you.
DWF Viewer 2013 linking to Revit 2014
Thu, May 9, 2013 at 9:43:06 AM
Revit Viewer
Fri, Mar 19, 2010 at 9:15:31 AM
Revit File Viewer
Wed, Mar 19, 2008 at 6:28:12 AM
Create Your Own BIM Tool in Minutes with bimU.io Viewer API
Thu, Sep 24, 2020 at 5:51:52 PM
Revit to Ifc to Third Party BIM Viewer
Tue, Dec 11, 2018 at 12:36:04 PM
Page generation time: 2.8409
