Forums >> Revit Building >> Technical Support >> Material scaling in cloud render
Hi,
check attachment,
when i render in the cloud my material gets scaled way to big.
anyone had this problem and found a sollution?
tnx!
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Are you sure that is the same material? I don't see any pattern at all in your image so it may not be a scale problem.
the big black lines in the cloud render, i dont see how you can not see them,
the texture on the right is about 30 times bigger then the one on the left.
peace is the path."
Mahatma Gandhi.
Those looked like you did the walls floor to floor without joining them. But if that is not the case then ....?
I thought the cloud materials can be set separately.
And since the vertical lines, line up, that is not your pattern.
Edited on: Wed, Aug 28, 2013 at 9:11:57 AM
it is my pattern, but,
my walls are drawn floor to floor but they are joint,
the reason the vertical line just keeps going is because the pattern just restarts at each level,
i have attached a image where i have enlarged my texture 30x in revit realistic view, and it gives the same result as my cloud render.
where can i set cloud materials seperatly?
i will look into it but i have never heard of this being possible...
Edited on: Wed, Aug 28, 2013 at 9:54:01 AM
peace is the path."
Mahatma Gandhi.
Looks like you are not unique:
http://therevitkid.blogspot.com/2013/05/revit-2014-cloud-rendering-and-custom.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+TheRevitKid+%28The+Revit+Kid.com!%29
They say SP1 for 2014 was supposed to fix this. Have you installed SP1?
Revit Architecture 2014 Update Release 1
solved!
Tnx WWHub!!!
peace is the path."
Mahatma Gandhi.
1 Posts No Rating |
I was having the same issue and it kinda creeped me out when it first gave me back renderings with HUGE lines like your rendering.. haha I'm gonna install the update fix now! thanks!
SCALING JPEGS FOR RENDER SCENES |
Mon, Oct 10, 2005 at 3:53:23 AM
Cloud render quality |
Fri, Apr 5, 2013 at 3:50:00 PM
Render in Cloud Problem |
Fri, May 24, 2013 at 8:19:23 AM
image when "render in cloud" black |
Tue, Jan 14, 2014 at 8:51:32 AM
Render cloud for Revit |
Thu, Jun 20, 2013 at 12:50:40 PM
Members: | 2098113 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
