59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 Revit.ini update deployment...
Tue, Aug 27, 2013 at 6:49:34 AM | Revit 2014 Revit.ini update deployment...
jmqrsq
5 Stars: 3 Votes
I have done several searches both here on this forum and on the web and cannot find a good response. I am wondering how a deployment newbie like myself can easily keep everyone on the network up to date with their Revit.ini file. I have read scripts or GPO to handle the push of the updated file but being very new to these concepts I am hoping someone out there has the time to explain to me how to set up a GPO exactly or at the very least give me a crash course in scripting for Revet deployments. I appreciate the time and any responses.
Thanks
Thu, Aug 29, 2013 at 8:11:36 AM | Revit 2014 Revit.ini update deployment...
chemstress
why would you need to change the revit.ini file?
Thu, Aug 29, 2013 at 8:31:26 AM | Revit 2014 Revit.ini update deployment...
Our IT guy builds the deployment from a PC but placing it on the server.  With the latest instalss, we have pre-tested and modified if needed, the ini file on a stand alone system and that ini is used with the deployment.  Every new Revit issue has its own ini file, it doesn't use previous versions.
Thu, Aug 29, 2013 at 8:49:49 AM | Revit 2014 Revit.ini update deployment...
jmqrsq
5 Stars: 3 Votes
@chemstress,
In case a custom network server path for say in house libraries or some other support directory on our server needs to change for whatever reason at a later date. The initial .ini file isnt an issue as that can be dispersed in the deployment itself, its the updates in th efuture on the Revit.ini file that I want to understand how to push out to everyone.... or any other file for that matter. I dont want to rely on users to have to find a file on the server and remember to update and overwrite that file to be up top date. it wouldnt happen
Edited on: Wed, Nov 6, 2013 at 10:21:46 AM
Revit 2014 Deployment question
Mon, Dec 9, 2013 at 11:09:10 AM
Revit 2013 & 2014 Building Design: Lookup Table and the Revit.ini file questions
Fri, Nov 22, 2013 at 5:46:42 PM
rvt2014: Best way to run deployment? (warning: deployment newbie question)
Wed, May 22, 2013 at 5:14:26 PM
Revit 2015 Deployment Issues
Tue, Apr 29, 2014 at 10:07:27 AM
Revit INI file
Fri, Jul 1, 2011 at 12:54:48 PM
Page generation time: 2.9582
