90 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Floor surface pattern not "folding" - how?
5 Posts No Rating |
Hello,
I'm doing a landscape architecture model in Revit 2013 and has used floors to define different ground materials such as concrete slabs. Most of the materials have surface patterns. I've modified the sub elements to individual elevations for the gradings of the surfaces, and in plan view the surface patterns look "folded", the patterns change directions at split lines created by the different elevations. Is there a way to get the patterns to remain straight even if I change the elevations?
Sorry - no way to do this that I know of in Revit except to break up the slab into individual planes.
5 Posts No Rating |
Thanks for the reply - would be a nice option to have. I guess it's also possible to create filled regions with the same shape as the floors and assign the right patterns to them, even if that's some extra work.
You do know that you can rotate model patterns for each section of the item? In the image below, I rotated the left patterns but not the right.
5 Posts No Rating |
Thanks, I didn't know about that (my pattern was a drafting pattern, too) but as my floors sometimes have curved edges the patterns act unpredictable (at least to me) when I rotate them. Guess I have to stick to filled regions for now, at least it's not all the floors that have patterns.
Material patterns should always be set as model patterns. Your right, how can linear patterns work with curved surfaces? They can't. Put a brick pattern on a cone if you want to see something interesting.
"Fishscale" Shingle surface pattern |
Tue, Feb 16, 2010 at 11:22:28 PM
Surface Pattern on Modified Floor - No Skewing for Floor Plans |
Mon, Sep 12, 2016 at 7:45:11 PM
Pattern Types... |
Wed, Jan 16, 2008 at 1:14:08 AM
"paint" pattern id? |
Thu, Jul 24, 2008 at 1:14:42 PM
Folding Attic Stairs |
Wed, Apr 18, 2007 at 1:13:52 PM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
