31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to make one callout tag with multiple views referenced
Thu, Aug 22, 2013 at 8:52:36 AM | How to make one callout tag with multiple views referenced
straub
Hello,
I am using 2013, and I was wondering if there is a way to make one callout tag to read multiple views in the project. I'll explain best with what I am trying to do ... I have a project where I have one room called out on the main plan, and a separate sheet in the project that shows that callout as an RCP, blank plan, and plan with furniture. I have already set up all of these views by making 3 different callouts and carefully overlapping the callout dashed line on the main plan. But the issue is that I want to just tag one of them and have the tag read (1,2,3/A-100) versus 3 tags that have (1-A/100)(2-A/100)(3-A/100). I wanted to know if there is a way to just put one tag on but override the text on it, or just what the best method would be to accomplish what I want.
Thanks in advance.
Thu, Aug 22, 2013 at 9:04:25 AM | How to make one callout tag with multiple views referenced
There is no way to do this and make it be automatic - which really defeats what Revit is all about.  Why not just use the single callout ...(1/A100) then on the sheet, move that title so it centers under all three plans and add text above that "Architectural Plan" / "Reflected Ceiling Plan".... whatever?
They other two plans have to be set to no title or a title that has no bubble.
Edited on: Thu, Aug 22, 2013 at 9:05:12 AM
copy & paste 'reference view' to other floors - have to readjust callout tags?
Tue, Jun 19, 2018 at 12:42:15 PM
detail callout tag, multiple times on the same view
Thu, Oct 8, 2009 at 1:16:26 PM
Referenced views floating in space
Thu, Oct 22, 2015 at 2:43:49 PM
Duplicating callout views...??
Wed, Oct 28, 2009 at 10:18:12 AM
Detail callout tag... for 2010
Wed, Nov 11, 2009 at 11:58:52 AM
Page generation time: 0.9845
