58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> door opening height not showing in dimension
Hello,
I'm trying to use the feature that enables the opening height to show up on the horizontal dimensions. It does pick on the windows, but I can't make it work in doors, though all documentation show it's possible. Any ideas?
I'm using OOTB doors in RAC 2014.
Many thanks
It works fine with mine. Make sure the dimension type is set to do this.
It is. Sometimes it picks up, sometimes it doesn't. And I haven'tmanaged to find out why.
Now that is a different question. Your original post said it didn't work.
Your problem is that you are not dimensioning to the door but mabe to the wall? Use yor tab key when you place the dimension and watch what it says you are dimensioning to (lower left).
The door family also has to have been built correctly with the left and right planes used for the opening set to "Is reference".
Door Family creation questions: Revit 2010 |
Mon, Nov 23, 2009 at 11:17:43 AM
12
Door family - opening covers door leaf |
Fri, Sep 30, 2016 at 4:36:46 AM
Hidden dimension segment |
Mon, May 3, 2010 at 9:06:52 AM
Door with Masonry Opening M.O. |
Fri, Jul 31, 2009 at 2:17:31 PM
demolish door with out infilling opening |
Fri, Jun 5, 2015 at 9:30:39 AM
Members: | 2022554 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
