66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Revit2014 - Error Message When Adjusting Viewport
4 Posts No Rating |
Hello. I keep on getting an error message when I try to adjust my viewport size by either draging the points in plan or elevation. If I try to change the size, an error message that says "Some elements were not copied. Cannopy copy elements." comes up. It's strange as I am not trying to copy anything. Does anyone know why it happens and how to fix it?
Thank you!
I have seen that anomoly. . . . . trying to think what the problem was . . . . are you using Worksets, Phasing or Design Options ?
4 Posts No Rating |
Thanks for your response. I am using Worksets, but no Phasing or Design Options.
it is also strange that the OK button is greyed-out/disabled... considering that this warning should/can be ignored
** dont be mad, i dont have much... i am homeless |
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016 |
Tue, Oct 4, 2016 at 9:09:33 AM
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 9:12:33 AM
Revit 2014 - Disappearing error message |
Wed, Nov 6, 2013 at 4:12:48 PM
Keynotes Error Message |
Mon, Jan 24, 2011 at 9:12:17 AM
Error Message |
Fri, Feb 18, 2011 at 2:24:25 PM
Members: | 2057494 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
