39 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Creating multiple curtain walls in normal wall
Hi guys is there a easier way to create multiple curtain walls in a single wall. The method I am using at the moment is splitting walls then changing the wall type to curtain. This is very long and difficult.
Thanks in Advance,
![coreed Avatar](user_avatar/14568.jpg)
The storefront curtain wall is auto-embeded in the wall.
Cheers, I thought you had to create multiple walls and join them together! Now I have done what you said created a curtain wall and cut the profile in to the main wall, works a treat!
Thanks!
Curtain Wall in a Slanted Wall? |
Wed, Aug 8, 2012 at 9:17:56 AM
Walls used as curtain panels - stop joining |
Mon, Feb 23, 2015 at 8:14:13 AM
Creating Curtain Wall Schedules |
Thu, Sep 14, 2017 at 11:59:47 AM
Door that cuts a curtain and a normal wall at the same time |
Sat, Jun 1, 2019 at 7:33:18 PM
BIG curtain wall room bounding problem!! |
Mon, Dec 14, 2009 at 9:31:31 AM
Members: | 2016873 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
