101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> chamfered beam visibility
Fri, Aug 16, 2013 at 12:19:05 PM | chamfered beam visibility
ledgewood33
I have created a beam with chamfered ends using void extrusions. I would like to know if there is a way to turn the chamfered ends on or off?
Fri, Aug 16, 2013 at 12:26:38 PM | chamfered beam visibility
3.5 Stars: 395 Votes
If the voids are located parametrically (lets say up/down) with an instance based location (reference plane), you can move the voids off the beam in the model.
Fri, Aug 16, 2013 at 12:42:09 PM | chamfered beam visibility
ledgewood33
I am not sure I follow. I created a reference plane to locate the distance from the top of the beam where the chamfere will begin.
I am going to try to attach the beam to this reply.
Fri, Aug 16, 2013 at 12:54:23 PM | chamfered beam visibility
Put this family in a model - plan view.  Now click on it and drag the grips in the center of the hole up and watch what happens.  Open the family and see how it is constructed.
Fri, Aug 16, 2013 at 1:01:03 PM | chamfered beam visibility
ledgewood33
I forgot to mention that I am using revit 2013. when I tried to open the fiile that you attached it said it was in a later version.
Fri, Aug 16, 2013 at 1:02:00 PM | chamfered beam visibility
Well - I don't have time to recreate that - you should always state what you are using in all posts.
Beam System Visibility
Wed, Mar 22, 2006 at 9:23:08 AM
VG problems with uploaded beam family
Tue, Aug 28, 2007 at 6:49:43 PM
Chamfered edge timber plinth
Mon, Jun 27, 2011 at 9:52:33 AM
Stuctural beam extension visibility
Wed, Mar 7, 2007 at 5:27:12 PM
Structural Beam Visibility
Tue, Feb 27, 2007 at 11:37:36 AM
Page generation time: 0.4533
