49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Structural Beam System
Fri, Aug 16, 2013 at 8:27:15 AM | Structural Beam System
SteveB
3.5 Stars: 5 Votes
Is there a way to control the way revit does or does not trim beams in a strutural beam system?   I understand that it wants to trim off the beam at the edge of a bearing condition, but that isnt (or may not be) how it works for a beam system on a bearing wall below.  See the sketch.
http://screencast.com/t/iEIRin6rLD
Also why does it shorten the reported lenght of the beam.? How do you control that. Again, see sketch linked.
Thanks!
Tue, Sep 10, 2013 at 10:18:54 PM | Structural Beam System
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
there are two length in beams. 'length' and 'cut length'.
'length' is from hinge to hinge for structural calculations, 'cut length' is real length of the beam object.
attached image should help.
want more?
You can get more tips at Enjoy Revit
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:44 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:52 PM
structural beam system irregularity
Fri, Dec 19, 2008 at 3:03:11 PM
Structural beam system visibilty
Mon, Jan 28, 2008 at 6:08:27 PM
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:03 AM
Page generation time: 1.8304
