122 Users Online (120 Members):
Forums >> Revit Building >> Technical Support >> Rotated Materials in Different Views
20 Posts No Rating |
In the picture attached, I have created a model in place roof sweep with a slate material. On my front and rear elevations, the material is fine; however, on my side elevations, the material has been rotated 90 degrees. Is there a way to rotate the material on these side elevations?
Thank you!!
You mean the "Pattern"? right?
If that's a "Model" pattern just select it and use the "Rotate" tool.
Yes, it is a model pattern. Although, everytime I try to rotate it (by tabbing through and selecting a single line of the pattern) it gives me an error message saying "Can't rotate element into this position." Did I not model the roof sweep correctly?
Obviously Revit is trying to rotate the element - not the pattern. Your selection process may be wrong so watch what you are selecting as it is noted in the lower left corner of your revit screen.
DWFX has rotated materials from RVT 15 |
Thu, Jan 22, 2015 at 2:36:35 PM
Family Extrusion Materials are rotated |
Thu, Sep 22, 2011 at 10:32:22 AM
Elevation Symbols on rotated plan view |
Thu, Oct 8, 2015 at 4:58:51 AM
Rotating views to project north |
Mon, May 28, 2007 at 3:46:10 PM
Linked Structural model not visible is certain rotated section views |
Tue, Dec 22, 2015 at 2:27:12 PM
11
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
