Forums >> General Discussion >> Revit Project Management >> Schedules formating
9 Posts No Rating |
Hi, is there a way to modify the Horizontal grid of a schedule?, aim working in the revision schedule for my title sheet and cant modify the Row Height of the Body Text, the icon to Resize is gray out for this row, it allow me to resize only the Title text only, any suggestion appreciate.
In all previous releases, the row height is set bt the fonts size. In 2014, you can only adjust the row height of the header rows - not the data rows.
9 Posts No Rating |
Hi, is there a way to change or modify the Font text and size of the schedule in the gray area?.
Thanks for any suggestion.
Sorry - that is still body text and is controlled by that setting.
Revit's schedules improved a little in 2014 but not very much.
24 Posts No Rating |
@WWHub,
Sorry if this is unrelated, but is there a way I can include a Key symbol into schedules. For e.g. I want to create an appliance schedule, tagged all my appliances in plan or elev with tags ( a hexagon or some shape) with a number in it. Can I show this symbol in schedules, so it'd be easier for the contractors to understand which is tag is for what.. you know.. like how's it's done normally. I tried everything but I coudn't find a way. I am pretty sure it's not possible... and but still wanted to check with you.
Thanks in advance.
In Solidarity |
In 2014, you can add an image in the header area of schedules but I don't think you want that.
We keys like this below our schedule.
No, but thanks !!
In Solidarity |
9 Posts No Rating |
Hi to all, can somebody guide how to edit the discipline wording of the schedule sheet index.
Thanks.
The discipline parameter is a system parameter and not editable.
Create a new shared parameter and assign that to sheets to use instead of the discipline catagory.
Revit and SKM |
Tue, Aug 25, 2015 at 4:45:29 PM
multiple schedules |
Tue, May 1, 2012 at 1:04:42 PM
door schedules from one project to another |
Fri, Aug 21, 2009 at 10:04:08 AM
Schedules for Information In Schedules HAHA |
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets |
Thu, Apr 27, 2006 at 11:01:59 PM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
