53 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> export IFC
hi
i created new crosshead, pile and pilecap using default generic model family and then just change the catergory to my desired family.
my problem now is when i export my ifc,,, and upon checking it, they are now under generic models and not the family category i chose.
is this supposed to happen? kindly help, thanks.
using RVT13
tried: 2x3 and coordination view 2.0
** dont be mad, i dont have much... i am homeless |
update:
tried to install exchange apps: ifc exporter for revit 2013 <-- still no change
tried to open and update my file in rvt2014 and do the export ifc there <-- still the same
whats the catch here?
im guessing you cannot use the generic model family and always use the correct family template?
UPDATE
good news from autodesk (hoping!!)
and i quote:
"I understand that you have an inquiry regarding family category issue for structural framing elements when exporting IFC.
For this issue, I was able to replicate the same and this issue will be escalated to the development team. We will keep you updated whenever there are any updates from the team. "
Revit MEP IFC Export - Objects not detalied |
Wed, Jul 2, 2014 at 8:08:29 AM
Revit Family Export to IFC |
Fri, Nov 29, 2013 at 4:29:41 PM
IFC export: Gross Area |
Fri, May 29, 2009 at 3:01:19 AM
IFC Export - Unrecoverable Error - Aborted |
Wed, Feb 26, 2014 at 8:15:09 AM
IFC export |
Wed, Oct 28, 2009 at 12:02:48 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
