74 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Unable to end commands/exit edit mode
1 Posts No Rating |
I'm using Revit Architecture 2012, of course with a project due, and am experiencing a problem that has completely halted any output. It seems that when I attempt to form a floor, or stairs, or any command of that nature, the only way to end the comman d, or exit edit mode is to ctrl-z my way back to nothingness. Esc doesn't seem to cut it. I have an important project due yesterday, any help would be mucho appreciated. Thanks
![5 Stars: 3 Votes](/images/stars_5.gif) |
last time we encounter ribbon problem in our 2013, coz we install 2014. the update release for 2013 help solved that..
its worth trying it: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944#section3
it seems you got a ribbon issue also, because the only way to exit sketch mode is to click X or CHECK and to end command is to click the ARROW below application menu. (except escape and CTRL+Z)
** dont be mad, i dont have much... i am homeless |
Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344242&linkID=9273944
For future reference, you can cycle throgh menus by double clicking on the tab bar (Revit -dark grey bar at the top).
Edited on: Wed, Aug 14, 2013 at 7:30:07 AM
Can't exit sketch mode |
Tue, Oct 22, 2019 at 7:19:00 AM
Stairs Disappear upon edit sketch mode. |
Wed, Jun 6, 2018 at 12:49:18 PM
group edit mode |
Mon, May 27, 2013 at 8:32:56 AM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
Concrete Beams |
Tue, Nov 11, 2008 at 3:33:21 PM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
