61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> schedule locations
Fri, Feb 10, 2006 at 1:07:12 PM | schedule locations
hippy
They want locations in my schedles. Floors,railings windows doors. Is there any way I can display which room doors and windows are in,associate to the room tag? Maybe a way to include the location in the tag name for floors and railings. Tried keynotes but it would be easier just typing them in manually cause geneally I don't need to identify them on the plan just in the schedule.
Sun, Feb 12, 2006 at 8:30:33 PM | RE: schedule locations
douggodfrey
You can define a ROOM NAME parameter inside the family, e.g. open your window family and add a shared parameter that you have already set up in your shared parameter file called ROOM NAME. If you are not familiar with shared parameters, read through the help files. after you have re-loaded the family into your file, you can enter the "value" of the ROOM NAME in the property dialogue for each window or group of windows if you have more than one window per room. once you've identified all your windows to their specific room, you can sort or filter your schedule using your new parameters.
Mon, Feb 13, 2006 at 12:28:43 AM | RE: schedule locations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only Doors and Windows are room aware: In your schedule you can add fields for FROM ROOM or TO ROOM.
Tue, Feb 14, 2006 at 11:51:46 AM | RE: schedule locations
hippy
that was easy thanks again
wall schedule with locations
Thu, Nov 7, 2013 at 3:29:33 PM
Schedule room locations of Detail items
Mon, Aug 14, 2017 at 11:10:24 AM
Using Client's Coordinates and Scheduling Columns To Show Locations
Tue, Jun 7, 2016 at 2:50:41 PM
Custom Locations for Sun Studies - RA2009
Wed, May 21, 2008 at 5:56:25 AM
Ceiling Locations
Tue, Jan 11, 2011 at 11:36:36 AM
Page generation time: 0.8594
