35 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> revit plotting to pdf
Tue, Aug 13, 2013 at 8:31:06 AM | revit plotting to pdf
easter
easter Avatar
Dear all,
we have a revit MEP model that has 2d CAD backgrounds in true color. all our line work and families are also in color and we have a real issue with the length of time it plots to pdf. around 5 min per sheet.
i thought it might be the amount of color on the sheets, true color for the background but i have changed these and we still have the small issue
so does anybody else have any more sugestions
thanks
Tue, Aug 13, 2013 at 8:38:54 AM | revit plotting to pdf
It may not be a color issue but instead filled regions or tiny line segments. Filled regions created using linework (hatches) may be the problem.
Is the CAD linked or inserted?
Tue, Aug 13, 2013 at 8:42:38 AM | revit plotting to pdf
easter
easter Avatar
all the cad files are linked. i will try to look at the colored regions all though we dont have many of them
Tue, Aug 13, 2013 at 9:17:50 AM | revit plotting to pdf
Regions / linework in the CAD file.....
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:06 PM
RVT 9.1 - plotting as PDF changes lines to halftone
Tue, Jul 24, 2007 at 3:54:19 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:52 PM
Setup PDF plotting in Revit
Fri, Apr 15, 2011 at 1:06:52 PM
Plotting with PDF in Revit
Mon, Sep 24, 2007 at 10:05:24 AM
Page generation time: 5.7282
