83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Copy/ Monitor Generic Models
Mon, Aug 12, 2013 at 12:02:51 PM | Copy/ Monitor Generic Models
JackctByrd
JackctByrd Avatar
Working in Revit 2014 I am trying to find out if I can copy/ monitor a generic family. I have a structrual model that owns and locates my mechanical equipment, the mech equip are created as generic families versus changing them to mech equip in the settings. In my mech model after I have linked in the structural I can C/M diffusers and grilles but it won't let me get the mech tools. Any thoughts and help would be appreciated.
Mon, Aug 12, 2013 at 12:22:38 PM | Copy/ Monitor Generic Models
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
From your Help file...
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2214-Collabor2214/2357-Multi-Di2357/2358-Copy_Mon2358/2360-What_Ele2360
What Elements Can I Copy or Monitor?
Table of contents No headers
  • Revit Architecture iconRevit Architecture
  • Revit Structure iconRevit Structure
Use the Copy/Monitor tool to monitor changes to the following types of elements:
  • Levels
  • Grids
  • Columns (but not slanted columns)
  • Walls
  • Floors
  • Openings
  • MEP fixtures
When monitoring walls, you can specify whether to monitor openings, including openings for doors and windows. When monitoring floors, you can specify whether to monitor floor inserts and openings, such as shafts.
The Copy/Monitor tool is not intended to be used with:
Failure to Copy/Monitor Correctly
Thu, Oct 20, 2016 at 3:38:51 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Page generation time: 1.2313
