118 Users Online (117 Members):
Forums >> Revit Building >> Technical Support >> Add Yes/No Instance Parameters to Test
105 Posts No Rating |
Revit Architecture v2013
In a Component I am creating I have a line of text that I want to be able to turn on and off with a Yes/No Instance Parameters. How do I do that?
Model text in families can be controlled just like other model elements.
I should have mentioned this as well, but I did not think of this at first. Because it is a title block/sheet I do not believe it has model text (or lines). I have an example here of one that someone did it with just lines and text in a title sheet but I cannot figure out how.
We have a preliminary "stamp" in our titleblock which is an annotation symbol (text plus lines) with visibility being a type driven switch.
Exactly whay I am looking to do. That is not model text or lines as far as I can tell so how do you add a Yes/No Instance Parameters to those? Or am I missing something really stupid.
I just told you! It is a seperate family (annotation symbol) loaded into the titleblock and the visibility of that item is set to a y/n switch.
Instance Parameters Resetting |
Mon, Jan 28, 2019 at 1:20:31 PM
Adding Parameters to Walls |
Fri, Mar 15, 2013 at 10:26:04 AM
Instance Parameters [ 1 2 ] |
Wed, Aug 15, 2007 at 6:10:55 PM
16
INSTANT PARAMETER SCHEDULEABLE |
Wed, Jul 11, 2012 at 12:26:36 PM
Deleting Door Instance Parameters |
Fri, Oct 17, 2008 at 8:58:06 AM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
