84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Design Options doesn't seem to be working properly. Help
Mon, Aug 12, 2013 at 9:47:27 AM | Design Options doesn't seem to be working properly. Help
sippel26
I am having problems displaying the primary option set in the main model.  I have seperate views for each option with the visibility set to reflect intended option.  I have a base floor plan that is intended to show which options are to used based on what option is set to primary.  The visibility setting in the base floor plan is set to show all, which I figure shows the designated "primary" design option of the option sets.  When I switch between different options or make different options primary the main model doesn''t show the intended change.  I thought the main model was suppose to reflect what is designated as primary, am I wrong?  I'm trying to show optional bath layouts, optional closest, things like that which I figure wasn't to hard to do in design options but I cant seem to get the main model to show what options are being chosen.
Mon, Aug 12, 2013 at 9:53:44 AM | Design Options doesn't seem to be working properly. Help
You should control your design options through your VG settings.
Mon, Aug 12, 2013 at 9:59:28 AM | Design Options doesn't seem to be working properly. Help
sippel26
Thanks, that worked.  I guess I'm confused now why do I have the option to make a design option "primary" under the design options tab but also have the ability to do it in the VG settings?  I'm a bit confused.
Mon, Aug 12, 2013 at 10:12:48 AM | Design Options doesn't seem to be working properly. Help
sippel26
Nevermind I figured it all out through the VG settings, thanks.  Not sure why my post duplicated.
Mon, Aug 12, 2013 at 10:35:22 AM | Design Options doesn't seem to be working properly. Help
You can set your VG for a specified view to any option in any option set or you can set it to what is currently activated.  Obviously, to control the project, you are better off to fix the view to a particular DO and name the view appropriately. If all DO sets are set to "Automatic", then unless a DO in that set is being edited, then the "Primary" DO will be displayed by default.
The BASE option is all elements not in a DO.
Design options - Working with the design options
Tue, Nov 1, 2016 at 12:26:16 PM
Design Options
Wed, Jun 21, 2006 at 2:52:50 PM
Any way to change the order of Revit Design Options in the list?
Tue, Nov 1, 2016 at 12:33:22 PM
Design Options in linked files - possible to set 'permanently'?
Fri, Oct 29, 2010 at 9:26:45 AM
Design options issues
Thu, Mar 2, 2006 at 10:35:32 AM
Page generation time: 0.9956
