80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Profile folder locations
10 Posts No Rating |
Another file location question... When we create a new shape / profile (ie: fascia detai) which folder should it stored in?
You could store it in the Profile floder in the Imperial Library, but the issue with doing that is when you upgrade you'll have a new Imperial Library and you'll loose all the profiles and other families you created. You should either create a library on you office server and manage the files in a similar manner as the Imperial Library, that way other users can use/share families, or if you're a one man show, create a library somewhere on your on hard drive.
17 Posts No Rating |
Concerning losing profiles upon upgrade. If, prior to upgrading, the template drawing is saved as a regular revit project file on a protable harddrive would you still lose your profiles after upgrading? I would then open the saved file and save it as a template file in the template file storage location.
To solve this problem and to maintain our own families, we have added an office created sub-folder to every library folder. We keep our office created/updated families in these folders and we ask our users to go there first rather than just using the REVIT supplied families. By doing this, we can easily move our families to the new REVIT library when an upgrade occurs.
Can't blend two similar sweeps into mitred corner |
Thu, Jul 14, 2011 at 11:41:35 AM
saving new profiles?? |
Sat, Sep 27, 2008 at 10:27:09 AM
Revit 2015 Deployment Issues |
Mon, Apr 28, 2014 at 6:57:03 PM
profile sweep help |
Mon, Sep 21, 2009 at 4:48:04 PM
Local and Central File locations |
Tue, Sep 12, 2006 at 10:04:32 AM
Members: | 2057574 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
