62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Thick Datum Line appearing in sections only???
Fri, Aug 9, 2013 at 4:53:05 AM | Thick Datum Line appearing in sections only???
SPALDEN
Hi, I'm after a bit of guidance regarding a datum line I need to appear on a set of section drawings. I have a site where the tops of the buildings cannot exceed a certain level. The client has requested a big thick green dashed line to be shown on all section and elevation drawings at the specified level. I have somewhere in the region of 50 sections and elevations already setup so going through them all individually is going to be a pain.
My idea was to extrude a surface in 3D at the set level across the whole site, set it not to appear in any views other than sections and include a symbolic thick green line which appears when a section is cut through it. However, I can't set the element not to appear in 3D.
Surely there's an easy way to do this? Any ideas would be greatly appreciated. Many thanks.
Fri, Aug 9, 2013 at 7:27:48 AM | Thick Datum Line appearing in sections only???
Why not a 3D line of appropriate color and type that is placed in a seperate workset that is normally off in all views?
Basement Datum Level Line: Now you see it, now you don't
Fri, Nov 18, 2011 at 11:41:49 AM
Levels - True v's datum
Thu, Oct 9, 2008 at 1:30:05 PM
Datum Levels
Tue, Jul 1, 2008 at 4:18:53 PM
Ground line not consistent
Tue, Jul 29, 2008 at 11:56:51 PM
Sections tag
Mon, Apr 6, 2015 at 9:50:58 AM
Page generation time: 1.0561
