87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stairs
Thu, Aug 8, 2013 at 3:11:46 PM | Stairs
CYBERCAT
1 Stars: 1 Votes
Hi,i'm using revit 2014,how do i change stair waist thickness oo a monolithic or precast stair.I know that in previous versions you could adjust the stringer carriage height,i am not seeing that option.Thanks in advance.
Thu, Aug 8, 2013 at 3:38:34 PM | Stairs
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Whats a  stair waist thickness exactly ?
Image . . .
Thu, Aug 8, 2013 at 10:11:30 PM | Stairs
CYBERCAT
1 Stars: 1 Votes
Hi,Sorry please see attached image of what i call the stair waist.It is really the distance between the underside of stairs and riser/thread combination.
Fri, Aug 9, 2013 at 8:20:53 AM | Stairs
Thread Post Kudo! #4
mansell5
3.5 Stars: 4 Votes
gday there,
try this ,
click on edit type, duplicate and rename (so you dont lose the current settings).
then, under run type, and structural depth , double click on the right hand end of
the structural depth line, another type properties box opens, where you can adjust structural depth or waist as you call it or throat as i would call it.
after adjusting the structural depth value, click on OK, apply ETC TO CLOSE OUT AND STAIR SHOULD UPDATE.
cheers
geoffm
Sat, Aug 10, 2013 at 1:00:31 AM | Stairs
CYBERCAT
1 Stars: 1 Votes
Hi Geoffm,thanks for your help it was of great help.I really appreciate your time and effort likewise for others who have invested their time.I'm hoping i'll become quite as proficient to help others.A bigger "CHEERS" to you..peace Cybercat.
Tue, Dec 3, 2019 at 1:08:28 AM | Stairs
ddynamic
I must say that was helpful. Who would have thought there was an invisible button in the run type field. Thank you.
Edited on: Tue, Dec 3, 2019 at 1:09:58 AM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 0.3095
