85 Users Online (84 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> SDS/2 Connect Now Available For Revit Structure 2014!
2 Posts No Rating |
SDS/2 Connect 2014 is Now Available!
SDS/2 Connect is now available for Autodesk® Revit® Structure 2014. The 2014 version of SDS/2 Connect includes all the same features and functionality as SDS/2 Connect 2013:
- Automatically design connections within the Revit environment. The combination of Revit Structure with SDS/2 Connect helps make it possible for structural engineers and fabricators to design, conduct code check analysis, and extend steelwork designs to fabrication within a BIM workflow.
- Print out all corresponding calculations at the push of a button. These connections are designed based off an extensive setup that has been developed in the SDS/2 Detailing product over the past 30 years. Using a specific input reaction or a percentage of uniform allowable load, SDS/2 automatically determines the correct hole and weld sizes, plate thickness and bolt types for each connection and creates the solid representation.
- Roundtrip the model and connection information with SDS/2 Detailing software. It is invaluable for engineers who desire to specify exact connections because they can transfer all the information to detailers using SDS/2, which eliminates any guess work or ambiguity. SDS/2 users can then make the needed model additions and modifications, and transfer only the changes or the entire model back to engineers who have installed the SDS/2 Connect add-in.
To purchase the 2014 version of SDS/2 Connect, visit sds2connect.com. Be sure to enter FM2014CT in the Promotional Code field to receive a $500 discount on the purchase of the software. The code can be used through December 31, 2013.
Familiar in ADD in- Software - Revit SDS/2 Connect |
Thu, Aug 8, 2013 at 1:17:41 AM
Tekla vs Revit SDS/2 Connect |
Mon, Jun 24, 2013 at 6:50:18 AM
Structural Steel Connections in Revit for LOD 400 models |
Tue, Jul 2, 2013 at 6:15:33 AM
Connection Design now available in Revit Structure 2013 |
Thu, Jun 28, 2012 at 8:08:23 AM
Revit Structure Lt or Full Version? |
Tue, Sep 10, 2013 at 8:25:18 AM
Members: | 2022458 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
