Forums >> Revit Building >> Technical Support >> Dimensioning to CAD links in Revit - Dims deleted
11 Posts No Rating |
Revit 2013:
I have imported CAD links in Revit. I need to dimension objects in these links. If the objects in the link are modified in any way and then the link is reloaded in Revit, there is a error warning that states the objects have changes and dimensions don't apply, which consequently dletes all the dimensions. Is there a way to make the dimensions in Revit 'non-associative'??? Any ideas are greatly appreciated.
No. When you make changes to the CAD file the dimensions dont know what they are trying to read anymore so they get deleted. You need to remember that everything in Revit is "smart" and relates to something. No line no dimension.
It's been a while, but if I can remember. When dimensioning to items in linked files. You must put those dimensions in a workset so that when the linked file is re-loaded the dimensions will stay.
Edited on: Wed, Aug 7, 2013 at 12:15:45 PM
I'll give the additional workset a shot and post on the progress. Thanks for the input.
HAHA!!! Worked like a @$%#ing charm! Thanks Coreed!
I guess I spoke too soon! When a different user tried to open the file, Revit gives the same error and deletes the dimensions again!! What gives?
Something is funny. If get a chance later I will give it shot. Not in the office today. Is the linked file in a workset?
Edited on: Wed, Aug 7, 2013 at 1:46:57 PM
Yes, it's in a separate workset than the revit dimension notations. Enjoy the day off (wish I was in your shoes).
Cad links |
Sun, Jan 6, 2008 at 2:59:16 PM
Dims |
Tue, Jul 10, 2012 at 4:41:31 PM
Deleted Dimensions w/ CAD Reload |
Tue, Feb 12, 2013 at 2:33:37 PM
Can I set CAD links to default to the foreground? |
Thu, Jun 23, 2016 at 4:58:32 PM
Auto Reloading CAD links on Project Startup? |
Thu, May 8, 2014 at 2:56:54 PM
Members: | 2098726 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
