74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Stringer in Stair by Run: Problem with offset
![kkohutek Avatar](user_avatar/38401.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
Hi everybody,
I searched all the way trough the Forum for an answer for this, but couldn't find.
Here's the thing: I use RAC 2013, and I know that a better way to do the stringers is using the Railling tool, I did that. But it's annoying me the idea that the Stringer Tool inside the Stair is not good enough.
I used the same profile of a metallic beam in both cases, but in this case the offset of both right and left lateral supports is off, when using Stringer (Closed). I can't manage to change the offset to make the stringer closer to the landing and run.
Only when you switch to Carriage (Open) that the offset is on again, but it doesn't allow me to add a profile to the Support.
So, my question is: what info do I have to change to make the Offset when using Stringer (Closed) on?
Thanks!
2 Posts No Rating |
-Who are you here? help me! plesea
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Help you with what?
2 Posts No Rating |
- what info do I have to change to make the Offset when using Stringer (Closed) on?plesae
-Thank!
http://www.revitcity.com/forum_files/122916_stringerbystair.jpg
Edited on: Tue, May 6, 2014 at 7:46:15 PM
Edited on: Wed, May 7, 2014 at 12:51:51 AM
Stair Stringer Offset |
Wed, Jul 15, 2009 at 2:20:56 PM
Stair stringer offset (2015) |
Mon, Sep 14, 2015 at 9:19:19 AM
REVIT 2015 Stair - Straight Run to Curve Run |
Thu, Dec 4, 2014 at 11:06:59 PM
Stair Stringer Question |
Fri, Jul 28, 2017 at 4:01:08 PM
Stair stringer slope doesn't match riser slope? |
Fri, Aug 21, 2015 at 10:30:14 AM
Members: | 2016968 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
